Did you solve?
It looks to me more a SW issue than an oil issue.
Did you solve?
I didn't read all the 45 pages of this thread, but reading last two pages, it looks like a solution to this problem has not yet been found.
So here it is my workaround: set the speed limiter to 70 km / h.
In this way, regardless of outside temperature, of how much you press the accelerator pedal and how steep is the slope, the combustion engine will NEVER start!
Explanation:
I examined the patent of the e-tech engine: it describes a coupler between ICE (Internal Combustion Engine) and HSG (auxiliary electric motor, High voltage Starter / Generator); HSG has 2 functions:
1) start the combustion engine
2) override electric motor upon electric gearshift
Unfortunately, this coupler is also described as "optional". This means that if it's not there, HSG and ICE (Internal Combustion Engine) are always mechanically linked: when HSG rotates, also ICE must rotate.
But, by design, HSG starts every time car reaches 75 km / h: when car reaches this speed, the main electric motor is turned off (to turn off the torque and allow gear shifting); at the same time, HSG starts to compensate power loss and reduce the acceleration loss of the car due to motor being turned off.
So, anytime you reach 75 km / h, ICE starts rotating. By design, it should rotate in idle, without consuming fuel, acting just as a mechanical connection between HSG and wheels; but it looks like SW is not properly written, hence as soon as ICE starts rotating, it is also turned on and begins consuming fuel. And probably once it is turned on, it's not safe for it to be turned immediately off, some minutes shall elapse.
Above mechanism also explains the big acceleration loss you encounter during strong accelerations:
HSG has just 25 kW power, while main motor has 60 kW; so, as long as you are accelerating using at most 25 kW, you will not notice at all the gear shift at 75 km / h; but if you are accelerating at 50 kW, you will feel a half-cut of the acceleration!
Alles anzeigenHello [user = '4237'] jumpjack [/ user],
That is provided by Renault so that it always activates after restarting the vehicle. It is a Renault safety policy. But you can disable it temporarily (while the car is in operation). Look at this:
[attach = '6671'] [/ attach]
On page 6.4 you can see how to deactivate "active braking" in the Easylink system, but only temporarily.
Best regards
Helmut
Yes, as I said I know how to turn it *off. But it's useless to do it, it automatically turns on again next time.
I don't know if I can post the link.... but you have just to add my nickname to wordpress.com and you have it
How did you succeed in disabling the emergency brake? I have the opposite problem: I want to permanently disable it because I think it is unreliable and then dangerous (it keeps raising false positives) , but it always turns on automatically when I turn on the car!
This is a very interesting thread...
Since I purchased my Captur on november 2020, I always heard this creepy noise coming from the engine at each gear shift, and I started to presume that my gearbox will not last the 3 years of the contract...
Now you confirmed my assumption: the e-tech clucth-less motor does NOT work, this car is not able to properly shift gears, and this results in gears damage at each shift.
It looks like they didn't take into account that a gear shift can be needed also when slowing down, not just when accelerating: if you pay attention to it, you can notice that shift errors occur upon shiftig down.
Indeed, on up-shift the HSG (auxiliary electric motor) overrides the main motor to suppress any torque and allow shifting; but what is it supposed to do upon down-shift?
(You can find a very detailed description of e-tech motor on my blog on wordpress.com )
